CJW8
Dec 05, 2015Explorer
Old-Biscuit wrote:
Air flow is needed (Draft) to remove heat from cooling unit.
Blocking off a couple of vents and using a 60W bulb helps when temps are below freezing....but not completely blocked off.
I did this this afternoon. Blocked 2 of 3 slots in lower vent cover and I installed a 60 watt bulb.
Observation- I can see ice crystals starting on back wall of left freezer compartment.
The center sealing strip between the double refer doors seems warm to the touch. I don't know why there would be a heater strip in this area. OK, I see 3 contact points on the door that make when the door is closed. I put tape over them to disable them for now.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
