Old-Biscuit
Dec 05, 2015Explorer III
You have 2 'moisture reduction heaters'
One is molded in the center divider section and the other is that flapper seal
Powered on anytime fridge is on. Flapper is turned on when left door is closed.
Not your lack of cooling issue
Ice crystals forming on freezer??
When you push the SET TEMP button does the number flash or remain steady?
Flashing...operating on 'BOS' backup operating system due to temp sensing failure. Duty cycle of heat source then has to be controlled via temp set point.
But it is sounding more and more like cooling unit blockage.
Check out this service manual.....LINK
Go to page 65 and then do cooling unit test following page 66 & 67
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
