dougrainer
Dec 06, 2015Nomad
CJW8 wrote:
according to THIS I reset the control board. Will see what happens. Results are so slow when working on these things.
This is the problem with these type forums(bad info). A RESET is ONLY for complete lock out of the refer, NO functions at all. So, your reset is useless. DO NOT block off the air flow. ANOTHER problem with these type forums. NEVER block off the air flow. You can install that light bulb. BUT, this procedure is for temps consistently BELOW 25 degrees. So, I would verify the rear cooling fans are running. Also, the temp of the freezer should be BELOW 10 degrees. If NOT, you have a major refer problem. The fact it is in a slide points to rear air flow(rear cooling fans inop). Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
