dougrainer
Dec 06, 2015Nomad
CJW8 wrote:
It is not in BOS mode. Rear cooling fans are running. I went through the diagnostics screens (thanks for the link to the service manual Old-Biscuit!) and nothing jumped out at me. There is nothing more I can check and will have to get it serviced. Today freezer is 35 F and ref. is 45 F.
The only thing I haven't tried is shutting it off for 24 hours and letting it settle. Would there be any benefit in this?
These temps do not make sense. IF you are getting 45 in the lower refer section(that means the evap fins are 35 degrees), then you should be getting lower than 35 in the freezer. HOW are you measuring the temps? If the temps are correct, then the cooling unit is BAD. Look for the dreaded Yellow powder/stain at the lower burner area, especially behind the insulation foil pack above the burner. BUT, if the cooling unit is bad/leaker, the Recall box should have tripped. Also, IF the temps are correct a NO CO code should also have been thrown. Doug
PS, you CANNOT use a Thermal Thermometer as a temp measuring device on a refer.
