CJW8 wrote:
SCV, There is no circulating fan inside the refer. The temperature probe for the test is in the middle of the second shelf from the top.
Doug, The refer is located in a slide. The RV is plugged into 50 amp service so converter is maintaining 13+ volts. The refer is facing the morning sun but is fully shaded by 11 AM.
You really need a single extra 12 volt fan mounted at the top access door blowing out for best results on a 1200 series or ANY refer in a slide room. I think you will be amazed at the better cooling with that 3rd fan. Doug
