RonWSl's avatar
RonWSl
Norcold 1210LR Heating Elements Failing
I installed a new amish cooling unit in my Norcold 1210 last August, purchased from http://rvcoolingunit.com/. In Nov., after 3 months, the unit failed, and true to their word and warranties, it was replaced very quickly at no cost (other then my time and labor to do the job twice). However, there is another problem. When I bought the replacement cooling unit, I also purchased two (2) new electric heating elements. Since then, both have failed. The vendor is also replacing them at no cost. But, my quesition and obviously my concern, is why are they failing - what would or could cause that. Danger? The failed ones are the shorter version with a 45 degree bend, and there is small hole near the lower end of the most recent one, almost like a burn thru hole. Anyone else had this problem? Soltions? Thanks.
  • I pointed my 1200 Norcold out the door and gave it a push today. And I am not regretting it. I get a Samsung on Thursday.
    Dave
  • Are they Norcold OEM elements? To have BOTH fail is extremely rare. Especially after 3 months. If NOT Norcold--THAT is your problem. Doug
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Dec 02, 2025
