dougrainer
Aug 17, 2022Nomad
https://www.amazon.com/ICQUANZX-Voltmeter-Measuring-Household-Measure/dp/B08RHT61GT/ref=sr_1_3?crid=1UW6E72RJ0Y5K&keywords=120+volt+lcd+plug+in+monitor&qid=1660756191&s=industrial&sprefix=120+volt+lcd+pluig+in+monitor%2Cindustrial%2C80&sr=1-3
THIS is what every RV needs in the kitchen area 120 plugs. Especially Motorhomes with Gensets. I use BOTH as a RV tech. It makes it very quick to determine if there is power to the RV. Faster than getting out my multitester. Most RV's have a cigarette plug at the TV booster wall plate. AND, most Motorhome Dash plugs, 1 will be connected to the Coach battery system. Doug
Below is also needed.
https://www.amazon.com/Jebsens-Charger-Battery-Monitor-Voltage/dp/B07K2XL6VX/ref=sr_1_37?crid=1BPUKRM0SQ9P&keywords=12+volt+lcd+plug+in+monitor&qid=1660756345&sprefix=12+volt+lcd+plug+in+monitor%2Caps%2C247&sr=8-37
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
