billyray50
Oct 23, 2013Explorer
Any other precautions regarding pulling out fridge hopefully only enough to work on the top of the fridge? Norcold manual says to Disconnect battery, shut propane tank valve off, bleed out propane on stove, disconnect propane near shut off valve, remove AC plug, disconnect dc wires from fridge, and remove the screws that fasten fridge to floor, and take off fridge door. Am I missing anything? Do I need to worry about the combustion seal?.. around the fridge mounting flanges...WHEW!!
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
