dougrainer
Apr 28, 2020Nomad
1. Your refer does not run on Chassis battery. It runs on COACH battery.
2. IF what your state is, when engine running or Genset/Shore Power, then you Coach battery bank is dropping below 12 volts and the Refer sees that and throws the code. So, you need your Batteries checked and Load tested. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
