drsteve
Jun 26, 2018Explorer
Old-Biscuit wrote:
What.how are you measuring temps?
How full is freezer?
Frost build up?
Have you checked freezer door seals....dollar bill test?
Are you using electric or propane?
Same results with either heat source?
Where is thermistor attached....which fin?
Any Fault Codes? (based on color of Indicating light)
Green and flashing off every 20 seconds
Amber and flashing off every 20 seconds
Red.....
Temps measured with a digital thermometer, empty freezer and fridge compartments.
Minimal frost.
Top compartment seals do not seem very tight. Bottom ones are only a little tighter. How good a grip should they have on the dollar bill?
Same results on either source.
Thermistor is on the sixth fin from the right.
No codes.
