nealshilltop's avatar
nealshilltop
norcold 611 frig
my 611 frig does not have the 16 pin connector as shown in the service manual so how do i reset the board
  • The P2-2 is the 6 pin connector that only has 4 wires in it. The ground open pin you use is between the Red and Blue wire. I assume you have a NO CO shut down code. The reset WILL NOT work if you have NOT corrected the reason it went into NO CO lock out in the first place. You can reset, but if you have NOT fixed the problem it will go into NO CO lockout again. Doug
    1. Turn OFF the refrigerator.
    2. Disconnect the following from power board:
    a. 12 Vdc positive and negative wires.
    b. AC power cord.
    c. Spark/sense electrode assembly wires.
    3. Remove the power board cover.
    4. Reconnect 12 Vdc positive and negative wire.
    5. Turn ON the refrigerator. It should be operating in the Manual AC mode (AC power cord disconnected from the power board).
    6. Insert one end of a piece of multi-stranded wire (10 gauge works well) whose insulation is stripped 1/2" on both ends, into the P2-2 opening and hold into place.
    7. Place the other end of the multi-stranded wire to ground (metal back panel) and hold it in place for a minimum of 10 seconds.
    8. Turn OFF the refrigerator.
    9. Turn ON the refrigerator. If "n" or "no co" code displays, repeat steps 7-9.
    10. Turn OFF the refrigerator.
    11. Disconnect the 12 Vdc power positive and negative wires from the power board.
    12. Install the power board cover.
    13. Reconnect the following to the power board:
    a. Spark/sense electrode assembly wire.
    c. AC power cord.
    c. 12 Vdc positive and negative wires from the power board.
    14. Place refrigerator in service.
  • I don't have a 16 pin plug on my control board to reset my fault code. 10 pin at the bottom of the board and a 6 pin at top left. Please help
