chuckt56ExplorerAug 25, 2013norcold 611ni'm sure from what i have seen several people have had similar problems so hopefully i can get an answer, i have a norcold n611 that will not cool in ac mode but will in gas as long as the ac cord is...Show More
camperpaulExplorerAug 25, 2013First: the "no co" code means "Not Cooling".Second: 108 VAC is the minimum voltage. It should be in the range of 108 to 132 Volts.Best case: your line voltage is too low.Worst case: you have a bad heating element.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 11, 2026
Related ContentNorcold 1210 Not CoolingNorcold Model 611 Fridge problemNORCOLD Refrigerator RemovalNorcold RefrigeratorNorcold on Inverter
