Chris_Bryant
Mar 29, 2016Explorer II
On a 6162, the switch that is either between the doors, or on the eyebrow needs to be on- if it is between the doors, it could well be bad. On the outside you will see the power supply board below the ignition module, there are 2 blue wires coming out of the power supply board- disconnect them and hook them together- they are made to do that.
Your model has no recall.
