dougrainer
Aug 19, 2016Nomad
bannerpilot33 wrote:
The line voltage drops to 114-115 with the air con on, but I've used this same facility and outlet the past 2 summers in a row with no problem. The only thing that's changed is the place has installed solar panels. Could my power cord need replaced? Switching to propane or running a cord direct to the fidge does not work.
You have a refer cooling problem. You need to find out what is wrong with the refer. You originally stated just on 120 and now you state BOTH 120 and LP lack cooling. VENTILATION (Lack of adequate) is common to both modes. Is the refer in a slide out? Are you POSITIVE the rear bottom to top ventilation is not blocked? Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
