jholder
Jul 12, 2023Explorer
dougrainer wrote:
Are talking you had a 30 amp plug installed or a 50 amp? Reverse polarity should NOT have blown the refer 120 volt fuse. BUT, you need to check for 120 on EACH SIDE of that 7.5 amp fuse. Use ground for 1 probe and the other on each side of the spades while the fuse is plugged in. Make sure the refer power cord is correctly installed on the control board and snug. Doug
It is a 30 amp plug. I wouldn't have thought that reverse polarity would blow that fuse either but that's when it happened, as I know it was working just minutes before plugging into the new outlet. Nothing else seems to have been affected oddly enough.
The power cord is all good, but I will check both sides of the fuse.
Thanks for your input.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
