wolfe10
Sep 14, 2016Explorer
Actually, the FIRST thing to do is a burner area tune-up. Could be nothing more than a flake of rust from the flue blocking the flame or a carbon deposit on the sensor.
Takes zero parts and no special tools (assuming your RV manufacturer left you with good access through the outer door to the burner area).
Yes, if it doesn't work after cleaning the burner tube, propane jet and igniter/sensor, THEN consider what part is needed.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
