dclarke618
Sep 18, 2016Explorer
OK,
I cleaned the burner, checked the continuity on the ignition/sensor wire and there is 12 volts to the valve while the ignition is actively sparking (20-30 sec)then the flame goes out and the voltage at the valve drops to 0. I think replacing the sensor/ignition wire is next.
Any other suggestions
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
