Fleet_Man
Aug 05, 2014Explorer
Recommend you get a piece of metal to attach to the bottom of the door under the hinge after you "glue" the broken hinge back together. Drill a hole through the reglued hinge and the metal plate and then reinstall the door. That should be the last time you experience that failure on that door hinge. I have a piece of 1/8" metal attached to the bottom of the door and angled out to the hinge with a hole for the hinge pin.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
