fcooper
Aug 06, 2014Explorer II
Fleet Man wrote:
Recommend you get a piece of metal to attach to the bottom of the door under the hinge after you "glue" the broken hinge back together. Drill a hole through the reglued hinge and the metal plate and then reinstall the door. That should be the last time you experience that failure on that door hinge. I have a piece of 1/8" metal attached to the bottom of the door and angled out to the hinge with a hole for the hinge pin.
Assuming that the door is similar construction to the Norcold NB811 I had, do not attempt to pry off the bottom trim strip as it is glued to the interior foam core of the door. I tried to make a metal strip for the bottom of the door, but there was nothing solid inside the door for screws to get a grip into....it's all foam.
I now have a nice Haier 120 volt refrigerator installed that we like.
Fred
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
