Lenny_K's avatar
Lenny_K
Norcold Double Door Fridge - Model 1210
In the past week every time we open the doors of the fridge we get a peculiar odour. It sort of smells like warm plastic or maybe rubber. Can't really peg down the smell, but it is strong and clings to the outside of every bottle and can. We've removed everything from the fridge and wiped every item plus the interior of the fridge. No joy. The smell inside of the fridge seems to be strongest in the left bottom. There is no smell outside of the fridge either inside of the trailer or outside of it.
Anyone ever had a similar problem?
  • The contacts are at the top of the door and look in good shape. The smell is strongest at left bottom inside corner.
    Don't have a icemaker and like you said, it would be in the freezer compartment.
  • Check the contacts between the door and cabinet- they provide power to the door flap heater, and they can get corroded and over heat.
    The only other thing I have smelled like that was due to a faulty ice maker- mold heater stuck on, but that was just in that freezer compartment.
