RonWSl
Aug 17, 2013Explorer
I didn' t transfer the recall kit over - it is not required on the amish cooling unit. All I did was run an extension cord for the 120, connected the 120 element leads to the board, and made a 12v jumper to connect to the 12v system. The gas is not connected. There are now 2 unused connections between the 120 element and 12v spades on the board where the recall leads had been attached.
I will run diagnostics and pull codes in the mornng.
Is something supposed ro arrach to the board where the recall kit leads used to be arrached?
Thanks.
The other posts on the error message was due to the recall kit. I will run diagnostics tommorow
Thanks.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 08, 2026
