ScottG's avatar
ScottG
Nomad
Jul 15, 2018
Norcold external fan control
I have a 10 cu/ft Norcold in my TT. The first time we took it out (nearly a year ago) the fan in the back of the fridge ran almost continuously even though it wasn't that hot out.
I have not heard it run since! Not even this last weekend when it was 102 outside. The fridge did maintain its temp fine though.
There's 12V coming out of the module in back to power the fan but it appears to have a sensor attached to a fin at the top of the cooling unit in series with the fan. I assume the sensor is not telling it to come on (can't get to it or the fan to check power).
Wouldn't you think the fridge would be working hard enough that the fan should come on?
I thought I had read that the fan comes on at anything above 70 (?) degrees?
BTW, fan kit looks like Norcold p/n 619020.
Thanks in advance,
Scott
  • Thanks for the link OB!
    And it's just as I suspected, installation dims are all way off.
  • Thanks all - OB thanks for the stat specs.
    Just ordered an APR system with fan control. Hopefully the fan is still good so the APR can become the controller for it.
    I plan on going over the installation in the process. There's a large open area over the top of the fridge that I suspect is open to the back. Also seems like the fridge is a bit far from the back wall.
  • 12V DC goes to the thermostat on the condenser fin.
    When condenser fin temp reaches 130*F it closes sending 12V DC to fans
    When condenser fin temp drops below 115*F the thermostat opens
    Via Roof top vent you should be able to reach thermostat
    Fans---you will have to pull fridge out several inches
    Lot easier to 'retire' in place and install NEW fans/thermostat via roof vent up higher.
    As long as fans PULL air in lower vent they will enhance the natural draft.
    Provided RV MFG bothered to install fridge following the Norcold recommended clearances, baffles if needed and no dead air spaces
  • The fan should come on at about 100 degrees.
    The sensor attached to the condensor is a thermostat.
    The heat from the frig even with 60 degree ambient temps should turn the fan on after a while of being on.
    I've had two of the fans go bad. If you bypass the thermostat your fan should run. If the fan runs when bypassed, it's a bad thermostat.
    Another way to troubleshoot, if it's 102 ambient, you should be able to measure 12V on both sides of the thermostat.
  • Those little sensors on the top of the coils are notorious for failing. They are only about $12. Replace it.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
