enahs wrote:
RV propane repair dealer I consulted mentioned that new burner can fit older models with a modification. Since it didn't apply to me, I didn't pursue it — but you might check it out. I think the burners are the same, but the new ones use a flare attachment.
That is what I was told also. If you have a flaring kit you can flare the old propane line that attaches to the new burner tube if not or if you screw up the flare you need to but a new propane line also. Right now the slider I made to adjust flame is working.
