Old-Biscuit
Nov 28, 2018Explorer III
VetPartTimer wrote:
Appreciate all the info everyone, thank you kindly!
I spoke to Norcold Customer Service, they were very nice and provided much of the same advice that you all have suggested.
I'm going to start by unplugging the thermostat and letting it run overnight on the propane to see if that is potentially the problem because it is the easiest.
Given that the refrig seems to work fine on AC power, I doubt it's the thermostat (but you never know).
Next will be to check for a good blue flame, maybe the valve is dirty.
Hope to get to this over the weekend, will certainly update you all on my findings.
Thanks again!
thermistor ----food compartment....measures Fin Temp
Electric or propane doesn't matter....same thermistor (thermostat also)
