dougrainer
Nov 28, 2018Nomad
Big Katuna wrote:dougrainer wrote:Big Katuna wrote:
Shouldn’t be rusty yet but clean/ check flame height, clean flue.
Get infrared thermometer and establish actual temps on elec vs gas.
You NEVER use a IR thermometer to verify refer or roof AC temps. In a refer you put in a glass of water. After 24 hours you use a digital thermometer to measure the water temp. That tells you the actual cooling of the refer. Doug
I’m having no luck balancing a glass of water on an ac duct.
Well, follow what I stated:B I said "IN A REFER YOU PUT A GLASS OF WATER". Kind of hard for an IR thermometer to read AIR coming out of a Roof AC duct. If I ever stated to RVP or Dometic I read the Air temp of a AC with an IR thermometer, they would have a good laugh and tell me that is NOT the correct way for Air temp measurement. Same with Dometic and Norcold on refers. I do use it on the Refer Evap fins, because that will tell me the state of cooling. Doug
