doxiemom11
Jul 08, 2016Explorer II
If it was in back up mode it would freeze everything in the refrigerator - at least that was our experience. Have you tried a reset? Unplug the 110, then unplug the DC plug ( our access is outside). Let it sit for a few minutes, then plug in the DC - then the AC (110) plugs. It may reset the circuit board for you for proper operation. Sound like your problem is it's too warm which could mean your thermistor is not working (like a thermostat). It's a cheap replacement and is inside plugged into the light with a wire running to the fins where it's clipped to the fins. Might try replacing that.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 29, 2026
