Carl_n_Susan
Aug 23, 2016Nomad II
I had the same problem. I tried fishing a thin wire down the tube but it didn't want to go all the way. Like you I was concerned about damaging the the tube.
I accessed the drain tube from the outside and discovered there is a little plug on the end. It's purpose to to prevent creepy crawlers from getting to the inside of the refer. It is designed to let water pass, but in my case was plugged. I removed it and blew the line with an air compressor to verify it was clear. No trouble since.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
