brirene
Aug 23, 2016Explorer
Carl n Susan wrote:
I accessed the drain tube from the outside and discovered there is a little plug on the end. It's purpose to to prevent creepy crawlers from getting to the inside of the refer. It is designed to let water pass, but in mat case was plugged. I removed it and blew the line with an air compressor to verify it was clear. No trouble since.
X2. The plug can be removed and cleaned. It has a small drainage hole that you'll be able to see once removed. I just cleaned that, didn't have to blow out the line.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
