dougrainer
Aug 23, 2016Nomad
The drain hose is easily found next to the Burner flue from the outside access door. It is a white hose. On the end of the hose is a plastic check valve. Usually, this check valve gets clogged. Just remove the check valve and clean it out and reinstall. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
