johnm1
Aug 24, 2016Explorer
I looked at the drain when I got home last night. I guess I'm used to Dometic fridges because the Norcold has a ~1/4" flexible hose that goes from the inside of the fridge (condensate drip tray) to an "evaporation" tray next to the burner flue/chimney thing. There's a small "anti bug plug" on the end of it. Not at all what I'm used to seeing on all of the Dometic's that I've had in the past.
Either way, I was able to gently blow backwards into the fridge and all seems OK now. Pretty much like Doug's post above.
Thanks for the suggestions!
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
