dougrainer
Sep 11, 2021Nomad
The Defrost cycle is 48 to 54 hours AFTER it is turned ON. If left on 24/7, it will defrost every 48 to 54 hours. ANYTIME the refer is turned OFF, the 48/54 cycle restarts from the time it was turned ON.
The Defrost is NOT the same as a residential refer with Heat elements and a defrost timer and a place for the water to go. ALL the refer does is turn OFF for about 2 hours to allow the Evap fins to defrost the ice on the fins. The freezer will probably not do anything as a 2 hour shut down will not cause it to get that much warmer. The ICE on the fins degrades the ability to cool the lower section. Ice is an Insulator. Doug
PS the water from the evap find will go thru the standard drain pan and out the drain hose to the rear of the refer and be evaporated hopefully by the HEAT from the cooling flue.
