Joe417 wrote:
Homefor2,
Your furnace and generator(if you have one)are the last two appliances on the line. (unless they have changed the plumbing).
I usually fire up the furnace to prime the line. Because it uses larger amounts of gas, it will usually fire up on the first or second try. The frig fires up immediately.
If you have the quick disconnect fitting, you can plug it into the outside appliance connection to purge the line in a few seconds. That keeps from grinding the generator starter to purge.
What makes you think the Genset and the furnace are "last" in line? If the LP Genset is in front and the LP tanks are in front, the LP Genset is direct to the tanks and not "Last". The LP appliances are connected to where they are mounted. There is NO standard to have any appliance ahead of any other. LP gas pressure is the same thru out the RV, so NO appliance needs to be in a certain place. On a Trailer(Most) the LP tanks are in front, the Refer can be at the rear of the RV and if the LP in the system has been lost, then the refer will take 4 or more tries to light to bleed the loss of LP in the line. Doug
