Anonymous
Trackrig
May 06, 2017Explorer II
henleyd wrote:
I'm amazed!! I went to lowes, got a small size magnet. Plugged the fridge back up. Moved the magnet around on the sensor switch, the red light went OUT and the default code inside stopped blinking. The fridge is cold, got ice, saved $200 + likely. The local rv dealers at lake of the ozarks can kiss my deplorable posterior. They weren't any help. These forums are us taking care of one another. Thanks.
What I carry, and you may of had but didn't think of, is one of those magnets on an expanding stick or wand for betting things out of cracks when you drop them. Mine have strong magnets on them.
Also, something you should read up on is if the sensor fails completely, there's a way to wire in a bypass. I had to do that because of the original retrofit sensors were failing.
I believe the current retrofit sensor should have REV E or Version E on it, but someone may be able to correct me on that.
Bill
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
