dougrainer
Jul 18, 2023Nomad
LP pressure is suspect if you have those temps on 120. Also dirty burner flue tube. Blow out with compressed air. You do operate the LP on HI setting? The service manual is adamant. NO FLAME change height unlike bypass LP tstats. So, if you get a flame height change, your LP tstat may be bad after verifying LP pressure(11.5). YES, an IR will work for the freezer wall temp. Your 30 degrees, was that with the IR and what did you point it at when you took that 30 degree temp? Doug
