dougrainer
Jul 18, 2023Nomad
mtnman1989 wrote:
How did you learn all this fridge info, were you a tech or do like I do and learn from personal experience?
I am a Master Certified RV technician with 44 years experience. TRUST ME when I tell you the details on how to troubleshoot and measure temp. You call up RVP(Coleman)/Dometic/Norcold and tell them an IR measurement, they will laugh at you. I do NOT know the difference between the 3 model numbers. There IS a difference between the 3 way and 2 way by the letter at the end of the N305. You NEED a LP pressure test. You will be spinning your wheels if it works fine on 120 but you have a problem with the LP without the pressure test. A not scientific way to test your LP regulator is to turn of the refer on LP. Then light the range burners on full. LIGHT the water Heater and furnace. Watch the Range burners. If the flames pulsate or diminish when you run the water heater and furnace your LP regulator is bad and needs replaced. You can also remove the LP burner and remove the orifice and blow it out. Is the refer in a slide room? Doug
