Good morning,
The temperature stays between 60-65 degrees.
It is in a slide. Last night someone checked to see if the fans were running. They couldn't confirm if they were running or not and will go back today with a ladder to get high enough to check.
Nothing has fallen down and the 5th wheel is level. We have been living in it since March, everything has worked well.
We don't have any fault codes.
I will also have the temperature sensors checked today.
Thank you for all your help. I will keep you posted on what we find out with the fans.
