garyemunson wrote:
You do not need to pull the fridge to replace the fans. Standing on a ladder you can easily reach in and replace them. We camp a lot in hot weather and I did this....much better and has served us well since installed.
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29770712/srt/pa/pging/1/page/1.cfm
If a 1200 is installed CORRECTLY, you cannot access the fans from the roof top or top access door if in a slide out. if you had access to those 2 fans, then the correct baffling was not installed. Doug
