Have a norcold fridge in my lance camper. For whatever reason it will not run on AC power. IT only will run on Propane. Light inside works fine. Stays cold on propane no issues. Any suggestions to...
Check the reset switch as a first measure. When you open to fridge compartment from the outside you will see 2 rubber buttons: one is the reset for propane and the other electric. They are not compatible with each other so do not try to switch them.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
