Have a norcold fridge in my lance camper. For whatever reason it will not run on AC power. IT only will run on Propane. Light inside works fine. Stays cold on propane no issues. Any suggestions to...
120VAC Outlet fridge power cord plusg into.....does it have AC Power? (Voltmeter) NO...then find source of AC to that outlet and reset it (120VAC Circuit Breaker, GFCI etc) YES...then need to check if the 120VAC FUSE on fridge is blown. If blown..replace it and most likely need to replace heating element (reason fuse blew)
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
