JohnJM
Dec 15, 2019Explorer
Norcold fridge
Have a norcold fridge in my lance camper. For whatever reason it will not run on AC power. IT only will run on Propane. Light inside works fine. Stays cold on propane no issues. Any suggestions to...
joelc wrote:
Check the reset switch as a first measure. When you open to fridge compartment from the outside you will see 2 rubber buttons: one is the reset for propane and the other electric. They are not compatible with each other so do not try to switch them.
