winstonmaberry
Oct 09, 2018Explorer
Again, thank you all for your willingness to help. I had watched a video that showed the igniter staying red out on the end while the burner was on. I got to wondering if mine was not getting hot enough to send the signal back to the board so I used a small propane torch to hold on the igniter and sure enough the burner would stay lighted. I then adjusted the igniter from about 3/16 to about 1/4 above the burner and at that point it did glow just a tad and the burner stays lighted. Yaaaaaaaaaaaaaaaaaa. Thank you again for your help, Winston
Having RV issues? Connect with others who have been in your shoes.24,388 PostsLatest Activity: May 21, 2026
