past-MIdirector
Feb 03, 2014Explorer
You pull the ice maker from inside the freezer. You have 2 to 4 1/4 screws and a electric plug. Make sure when you install the new ice maker the water inlet hose goes in the upper end of the tray, the same way as the old one came out. The solenoid should be the compatible or will have a new one which should be used.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
