bigtiki's avatar
bigtiki
Norcold ice maker failure, Kenmore M1...
My ice maker in my side by side Norcold stopped working recently. When I reach inside the cube containers have no water in them. I have checked the water cutoff selenoid and it is good when I apply 110 volts to the terminals. Then went to the Norcold website and got servicing information. When I remove the white cap cover on the unit to run diagnostics with a voltmeter, it is different than what is shown by Norcold. All i see are the gears for the bin. There are no test holes for the leads.It is identical however to the household Kenmore model M-1.
Time to pull and toss?
  • wolfe10 wrote:
    Please confirm-- your ice maker solenoid in your Norcold refrigerator is 120 VAC, not 12 VDC???
    its 120 volt
    Yes, and I disconnected the line and it functions.
    I also moved the extractor fingers for the ice cubes and the unit cycled ....once. now it doesnt.
    :h
  • sh410 wrote:
    Check on Amazon for a replacement. I got a replacement for under $50. Sears wanted over $160.
    Does one need access to the rear of the fridge to change it out for the water connection? Because I can't remove the fridge.
    Thanks!
  • Please confirm-- your ice maker solenoid in your Norcold refrigerator is 120 VAC, not 12 VDC???
  • Check on Amazon for a replacement. I got a replacement for under $50. Sears wanted over $160.
  • I would bet someone previously replaced it with a non Norcold model icemaker. IF your water solenoid operates with jumping and NOT with the Icemaker, the icemaker needs replaced. There are no serviceable parts inside the mold assbly. Doug
