nineoaks2004 wrote:
nineoaks2004 wrote:
I just dropped my Unit off at CW in Dothan with the same problem, I will let you know what they find.. Mine is still under warranty.
Service dept. stated that they have never seen this problem, the burner pressure etc. is good. Bottom line is a new ( since unit is under warranty) reefer unit..
IF your refer operates correctly on 120 but NOT on LP, replacing the CU is useless. Go to another Shop. It will be interesting how Norcold deals with this shop when they state it works on 120 but not on LP and they want auth to replace the CU. Doug
