dougrainer
Jul 20, 2017Nomad
The OP needs help. Not a bunch of Yahoos arguing over which type refer is best in their opinion and the needs for their type refer. It gets annoying when someone posts help and we have to wade thru a bunch of BS. You don't like Norcold? Fine, just SHUT UP. You have made your point on EVERY Norcold thread for the past dozen years.
To the OP, need more info but I will assume you have the 1200 since you have 9 tstat settings. FIRST thing is to verify the rear cooling fans are running. THAT is the most common cause of low performance in the bottom and the freezer works. Doug
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
