dougrainer
Jun 27, 2018Nomad
If the fins are iced over, THAT is your problem. ICE is NOT a good conductor of cold transfer. The air in the refer has to travel over/thru the evap fins to have the Heat removed. If there is ICE build up, that will cause the refer to not cool. Retest after you defrost give it 24 hours. Doug
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
