Vette_Racer
Jun 27, 2018Explorer
Over 7000 FT they claim the frig may or may not work on propane, manual tells you to switch to electric. I have found that the temp switch in the flue has something to do with this depending on the way your problem presents. If you reset the frig on propane do you hear the burner try to light, (sounds like a big fart) after 3 times it will quit. If that is the case try jumping the flue switch with a jumper wire across the connection and see if that helps with a reset of the frig. I ended up using a fuse to jumper the two wires to the flue switch which is an overtemp switch to get mine to run in higher altitudes. Good luck!
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
