dougrainer
Feb 12, 2014Nomad
The 120 element either works or it does NOT. So, the first thing to do is verify you have 120 current to the Heat Element. IF you do, the Heat Element is bad and you need to replace it. If NO current to the Element, trace back and check any 120 fuses on the back of the refer. Verify the 120 plug has 120 power. Doug
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
