dougrainer
Mar 26, 2022Nomad
strokershovel wrote:dougrainer wrote:RLS7201 wrote:dougrainer wrote:
There are 2 parts. The Thermocoupler and the Safety valve. I have never heard of a Thermocoupler interrupter. What are you thinking is a thermocoupler Interrupter. Doug
Page 18
***Link Removed***
***Link Removed***
Richard
That is usually part of the replacement safety valve. Also, that is what turns the indicator light on. It should NOT cause a problem with keeping the LP flame on. Hence, I have never had to replace that particular part. Doug
The interrupter is what the thermocouple screws into and shuts the gas off if the thermocouple does not send the signal that the flame is going
No, the safety valve does that. The Interrupter just sends the signal to the inside light display. There are RV refers that have NO inside indicator light and just have the safety valve that opens and shuts off the LP(Thermocoupler connected). The safety valve is the same for refers. This type model has the interrupter to send the signal to the light. It may SEND the Thermocoupler signal THRU itself to the safety valve, but it is the safety valve that opens and closes from the Thermocoupler millivolt signal. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
