Old-Biscuit
Aug 10, 2013Explorer III
holdn2aces wrote:
I have leveled the trailer, do you think the cooling unit is faulty because after a reset it works very well, I can even make ice? I removed the roof vent cover and the vent is clear.
Was it level before?
Having it trip after 4-6 hrs.......resetting and then tripping again sounds like blockage. Unit turns on..begins cooling but due to blockage is finally reaching a point of no cooling detected so it trips.
Off level operation causes a slow down in fluid to vapor to fluid and begins to crystallize which builds up.........effect is accumulative
Vent is clear.......how about the air flow from lower vent across backside of cooling unit to roof vent.
Any obstructions OR excessive gaps/areas (dead air spaces)?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
